Executing Ansible Node in Runbook
Once the definition is completed, click Run to execute the Ansible node and view its execution log. The following is a sample of the execution log:
Tip: Due to some known issues of the latest versions of RedHat Ansible, if you notice any unfamiliar errors in the execution log when running the Ansible task, you can perform quick troubleshooting by logging in to the Ansible server and running the playbooks manually.
