Error Code Definition
The following table outlines the error codes used for log standardization and troubleshooting purposes.
#CategoryError CodeError MessageRoot Cause/Description
1
Discovery Failure
IAM-001-001Insufficient IAM Role Or PermissionsRequired permission is missing.
2AUTH-002-001Login And Get Token FailedThe client secret is expired.
3LICN-003-001Exceed The License LimitThe license is not enough.
4API-004-001Front Server is not configuredFront Server is not configured for API server.
API-004-002Duplicate API servers exist
API-004-003Proxy Error / API Endpoint Cannot be Reached
API-004-004Front Server cannot reach the Microsoft Azure Server Endpoints
API-004-005Insufficient authentication scopes
5
Topo Issue
NM-005-001Azure Node Is Missing1. IAM permission issue.
2. Code bug.
3. Azure API logic flow change.
6IM-006-001Azure Interface Is Missing1. IAM permission issue.
2. Code bug.
7
Path Failure
PF-007-001Python Error1. VRT/Path code bug.
2. New user case which is not supported yet.
3. Azure API format change.
8NF-008-001Find Next Hop Failed1. VRT/Path code bug.
9Path SlownessOM-009-001Lack of Out Interface In Route TableLack of out interface in VRT or Effective Route Table.
10NCT Retrieve FailureIAM-001-001Insufficient IAM Role Or PermissionsMissing permission required.
