Diagnosis Type for Intent Definition
The following table lists 8 types of diagnoses for intent definition:
| Diagnosis Type | Description | Sample |
Config Diagnosis | Define a config diagnosis based on the device configuration. | ![]() |
| CLI Diagnosis | Define a CLI diagnosis based on the CLI commands. | ![]() |
| SNMP Diagnosis | Define a SNMP diagnosis using SNMP OID through three methods: SNMPGet, SNMPWalk, and SNMPTable. | ![]() |
| API Diagnosis | Define a API diagnosis to enable the diagnosis of SDN/Cloud Network and SPOG Data View from an external system via REST API (such as Splunk, SolarWinds, and ServiceNow). | ![]() |
| Ping Diagnosis | Define a Ping/Trace diagnosis to diagnose device connectivity, which can ping and trace to the current device via front server respectively. | ![]() |
| Trace Diagnosis | ![]() | |
| Device Diagnosis Block | Define a device diagnosis block without SNMP/CLI/Config/API command. | ![]() |
| Intent Diagnosis Block | Add an intent diagnosis block with only the device-independent logic. | ![]() |
