Defining Ping Result Analysis and Output
  1. Extend a Basic Output node from the Table1 node.
  2. In the Output1 node, add two conditions and define it as follows:
    Condition1: $ping_result == True
    Condition2: $ping_result != True
  3. Output a message when Ping succeeds:
    1. Point to the Output node, click the icon, select Condition1, select Message from the Action Node drop-down list and click Extend.
    2. In the Message1 node, set the message level as Information and define the message: Ping successful!
  4. Output an alert message when Ping failed:
    1. Point to the Output node, click the icon, select Condition2, select Message from the Action Node drop-down list and click Extend.
    2. In the Message2 node, set the message as Error and define the message: Ping failed from $this to the target.
  5. Save and run the Qapp.
