Define Sub Table
The system supports defining sub table for you to filter the noise data from the base table. You can filter the rows by either keeping or removing the value at the specific columns routes (filtered by value), or keeping or removing the rows of the base table matching the conditions (filtered by condition), reducing the noise alert that may appear in diagnosis. For example, there is a table about IP addresses, and you can create a sub table to only keep the interface with the IP address configured.
