Define Discover and Black MAC List
Discover and Black MAC defined which MAC addresses are used or not in the ARP and MAC table lookup algorithm.
- Discover MAC address is a unique MAC address across the whole network, for example, a real server’s MAC address. If a VLAN Group is split into multiple VLAN groups, merge them into one VLAN Group by using the Discover MAC List.
- Black MAC Address is a MAC address not unique across the network. For example, if a network device is not in the domain, its interface’s MAC address may be in a different VLAN on multiple switches’ MAC Table or an HSRP virtual MAC address. When multiple VLAN groups are merged, you can use the Black MAC List to separate them.
The Main Use Flow:
