R12.1 JA-2025July15 Define and View Reference Map You can define a reference map for a saved path. The path reference map allows you to draw the golden baseline path on the map and use device notes to draw key configlets or troubleshooting recommendations on the map. For example: Use Path Description and Note to Document Path Design Define Path NI for Future Path Diagnose
