Creating Public/Secret Keys for Gateway Accounts
This section explains how to create a user account in the Gateway account with the necessary privileges to assume roles in the monitored accounts using the AWS console.
- Navigate to Identity and Access Management (IAM) in your AWS Management Console.
- Go to the Users section and click Create user.
- Select Attach Policies directly and proceed with user creation. You can add the policy later.
- Once the User is created, create an inline policy.
A sample policy in the JSON format:Note: Use the account ID to monitor your environment.
Code{
"Version": "2012-10-17",
"Statement": [
"Effect": "Allow",
"Action": "sts:AssumeRole",
"Resource": "arn:aws:iam::<12-digit first monitored account number>:role/<role created in previous step (NetbrainAccessRole)>"
"Effect": "Allow",
"Resource": ""arn:aws:iam::<12-digit second monitored account number>:role/<role created in previous step (NetbrainAccessRole)>""
} - Create an Access Key for the user and ensure it is securely stored. These keys will be required for input in NetBrain.
