Configuring Private Key
The following SSH private key types are supported in the system to access your network devices:
- SSHv1 RSA key
- SSHv2 RSA key
- SSHv2 DSA key
- Click the Private Key tab.
- Click Add to open the Private Key Settings dialog box.
- Enter an alias and click Browse to import your SSH private key file.
- Enter a passphrase twice if your private key is encrypted.
- Click OK.
Repeat step 2~ 5 to add more entries if required.
Tip: You can relate the private key with the SSH public key in the Telnet/SSH Login Tab. |
