Clear All Table Data
The table data can be cleared from the ADT main menu.
After data is cleared, the empty ADT still exists in ADT Manager. All the ADT data can be cleared (including manually added data and dynamic updated data) by this feature. A Confirmation dialog will prompt you to confirm this action.
