Clean Aged Monitoring Data
By default, the aged data is not automatically deleted. To release the disk space occupied by a large amount of aged data, you can manually clean it up.
  1. On the Home Page, click your login name at the upper-right corner and select Delete Aged Data.
  1. In the Delete Aged Data dialog box, specify the days for data preservation. The default value is 30.
  1. Click Save & Delete to save the settings and delete the data older than the specified days.
    Information Tip: To make the Delete Aged Data dialog box automatically pop up upon login, select the Show this message after login when more than 30 days' data is stored check box.
