Update vCenter Data in NetworkBrain through Benchmark Automatically
Since the discovery only retrieves basic data of your vCenter network, you need to execute a benchmark task to retrieve all data and build all components after the discovery, including topology, visual spaces and data views.
  1. Click the Start Menu (Icon
Description automatically generated) in the upper-left corner of your NetworkBrain desktop and select Schedule Task from the drop-down menu.
  2. On the Schedule Discovery/Benchmark tab, click Add Benchmark Task.
  3. On the Frequency tab, define the task frequency.
  4. On the Device Scope tab, check the Select external API servers to retrieve data of SDN nodes check box, and select a vCenter server.
  5. On the Retrieve Live Data tab, select the VMware vCenter checkbox.
  6. On the Additional Operation After Benchmark tab, select all the checkboxes in the Build Topology and Rebuild Visual Space areas.
  7. Click Submit.
