Update Aruba Orchestrator Data in NetworkBrain through Benchmark Automatically
Since the discovery only retrieves basic data of your Aruba Orchestrator network, you need to execute a benchmark task to retrieve all data and build all components after the discovery, including topology, visual spaces and data views.
- Click the Start Menu
and select Schedule Task from the drop-down menu.
- On the Schedule Discovery/Benchmark tab, click Add Benchmark Task.
- On the Frequency tab, define the task frequency.
- On the Device Scope tab, check the Select external API servers to retrieve data of SDN nodes check box, and select the API server for Aruba Orchestrator.
- On the Retrieve Live Data tab, select the Aruba Orchestrator check box.
- On the Additional Operation After Benchmark tab, select all the checkboxes in the Build Topology and Rebuild Visual Space areas.
- Click Submit.
