Viewing API Triggered Runbook from 3rd Party Tools
If the Execution tree is associated with an incident generated by API triggered runbook (via API stub or Event Template), the execution result of the respective Runbook Template will be displayed under the Triggered by Third Parties category.
In the summary view, you can click on View Result to open the respective Runbook and check the execution result of each Runbook Node.
