View Physical Network by Virtualization
Virtualization is divided according to the parent-child relationship of the devices, generally used for devices with virtualization enabled, such as ASA Firewall.
To view the details and the context maps of a node, proceed with the following steps:
- Select Network in the left pane of your NetBrain desktop.
- In the Network pane, select Physical Network in the Category field.
- In the View field, select Virtualization.
- Expand the ASA-AA/stby node to view its child devices.
Tip: The number next to each node indicates the number of its child nodes. - Select a node and the Context Maps tab to view its context maps. You can click Open Map to view the context map.
Tip: The context maps display the L3 Topology or L2 Topology.
- Click the Device Details pane to view the node’s detailed property, interface and IP interfaces.
