View L3 Topology for a specific device
- Click Data > Data Accuracy Discovery on the left Menu Bar from the Desktop.
- Click
after the Device Name, and search for the device you want to view.
- Click the Topology tab and then click L3 Topology.
Under the L3 Topology Tab, the table shows all the L3 Neighbors that belong to the current device.Note: For multi-ports connections, this table will display them via several port-to-port links.
