View Device Log
In the View Result window, click the
icon in the target entry. By default, the devices with data retrieval failures are listed.
- Click Export to export the log files. In the exported log file, the Retrieval Time (seconds) column now appears next to the Device Type column.
- Click the target device entry to troubleshoot with the detailed live access log at the bottom.
- Identify log lines where the time between an operation and its subsequent operation exceeds the input value.
Export this live access log, <filename>: hostname.log.
Open a new browser tab page to display log content.
The Live Access Log Pane can be dragged up and down to adjust its height.
- For devices with live access issues, right-click on the target device and select Shared Device Settings in the drop-down list. In the Shared Device Settings window, adjust the network settings and tune the device until the live access is successful.
- For decommissioned devices, press the ctrl key to multi-select all decommissioned devices. Then right-click on the target device and select Create Device Group in the drop-down list. You can delete those devices by device group or exclude them from the Benchmark device scope using Exclude Device Groups.
Tip: To show other devices, select a category from View drop-down list. |
Note: By default, the number of Retrieval Time is sorted in descending order.
