View Change Analysis Report
Change Analysis Report lists the change detection time, change details, and the number of changes for each device.
You can click Export on the top right corner to export the Change Analysis Report in .zip format to the local machine. The exported report contains a summary.html file and folders of change details for each device. The summary.html displays all the changes on the target device types for target devices within the specified time range. Each target device will have an individual folder named after its hostname, containing the comparison details for each target data type.
The following table lists the change analysis results that can be viewed in the report:
Parameter |
Definition |
Total Changed Devices |
The total number of devices with changed data. |
Total Changed Entries |
The total number of the data changes (by different data types and device types). |
Device |
Devices with changed data. |
Data Type |
Type of the data source which has changed. |
Latest Change Detection Time |
Last time when the data type change is detected. |
Change Details |
Compare in this column to view the comparison details. |
Total Changes |
The total number of changes for this data type on this device during the given time range. Click the hyperlink in this column to view the change history for this data type on this device. |
