Use Runbook Automation for Azure Network
Runbook Template can help you understand your Azure network design and troubleshoot network problems based on certain scenarios. Many useful functions such as DVT, Qapp, Gapp, and Compare can be wrapped into Runbook to accomplish your tasks.
A Runbook with the built-in Qapp Azure Network Security Group Logs can help you quickly identify important NSG related logs for each VNet on the map.
For how to use a Runbook Template, refer to Execute a Runbook Template.
