Use Path Description and Note to Document Path Design
You can edit the path description to describe what this path is about:
At each hop, the raw data of the path check and check results are displayed under Path Logic in the Path Detail pane. Meanwhile, users can create notes in the Path Logic pane for their findings regarding each step of the path calculation. The notes will be shared with other users.
