Updated Feature/File
Feature/FileDescription
Config FileThe configuration file of the device will be updated to the new one.
One IP TableThe old device name will be updated to the new name.
GDR
▪Device: The data of the new device will overwrite the data of the old one.
▪Interface: Keep the interface information of the old device, and delete the information of the new device.
Share/Private Device SettingsThe data of the new device will overwrite the data of the old one.
Device GroupOld device hostnames in the device group will be updated to the new hostnames.
SiteOld device hostnames of the site will be updated to the new hostnames.
MPLS CE List and VRTOld hostnames of CE devices will be updated to the new hostnames.
TopologyRebuild the topology manually to ensure its accuracy after clicking Keep the Latest.
MapThe old device names will be changed to the new names after updating the map.
Site MapThe old device names will be changed to the new names after updating the map.
Default Data ViewThe default data views of the old and new devices will be deleted, and the rebuilding of the data view will be triggered when the next time the map is open.
Data ViewOld device hostnames in the data view will be updated to the new hostnames.
Customized Device IconIf the users customize the device icons for the devices with old hostnames, the correspondence remains unchanged between the customized icons and the devices with new hostnames.
Context MapOld hostnames in the context map will be updated with new hostnames.
Other FeaturesThe data saved in some other features will also be updated.
