Tuning Options
The tuning options are effective for each device in the current domain.
Tuning Mode and Access ModeOptions
Auto Set Device Settings — overwrite the outdated access credentials in the Shared Device Settings with the correct credentials got by polling the credentials in the Network Settings.
Management IP — overwrite Management IP addresses according to the interface type priority in the Live Access Settings if the system fails to access the Management IP in the Shared Device Settings.
Login Username/Password — overwrite the outdated Tenet/SSH login credentials in the Shared Device Settings.
Privilege Username/Password — overwrite the login credentials of privileged mode in the Shared Device Settings.
SNMP Community — overwrite the SNMP community in the Shared Device Settings.
Lock Shared Device Settings if tuning succeeds — the access credentials in the Shared Device Settings for the successfully accessed devices will not be changed by any other live access activities (such as rediscovery).
Verify Device Settings — only verify the credentials in Shared Device Settings without overwriting the outdated ones.
Management IP — verify the Management IP in the Shared Device Settings
Login Username/Password — verify the Tenet/SSH login credentials in the Shared Device Settings
SNMP Community — verify the SNMP community in the Shared Device Settings
Access Mode — specify an access method according to the configuration on your devices for the Auto Set Device Settings mode.
Telnet Only — only use Telnet to access devices.
SSH Only — only use SSH to access devices.
Both Telnet and SSH — use Telnet and SSH to access devices.
Lock Management IP — Management IP will not be changed by other tasks.
Lock Front Server Settings — The selected Front Server will not be changed by other tasks.
Lock CLI/SNMP Credentials — The credentials will not be changed by other tasks.
