Supported Context Maps of NSX-V Nodes
The following table outlines the available context maps of each NSX-V node.
Node Context Maps
NSX Controller
Two context maps are supported for this node:
  • Layer 2 Neighbors displays the Layer 2 topology between the controller and its connected vSwitches.
  • Layer 3 Neighbors displays the Layer 3 topology between the controller and its gateway device.
NSX Manager
Three context maps are supported for this node:
  • Layer 2 Neighbors displays the Layer 2 topology between the manager and its connected vSwitches.
  • Layer 3 Neighbors displays the Layer 3 topology between the manager and its gateway device.
  • Logical Topology displays the logical topology between the manager and its managed NSX components (including Logical Switch, Distributed and NSX Edge).
NSX Edge
Two context maps are supported for the NSX Edge (HA) appliance:
  • Layer 2 Neighbors displays the Layer 2 neighbors associated with the selected Edge (HA) appliance.
  • Layer 3 Neighbors displays the Layer 3 neighbors associated with the selected Edge (HA) appliance.
Distributed Logical Router (DLR)
Two context maps are supported for the DLR (HA) appliance:
  • Layer 2 Neighbors displays the Layer 2 neighbors associated with the selected DLR (HA) appliance.
  • Layer 3 Neighbors displays the Layer 3 neighbors associated with the selected DLR (HA) appliance.
Logical Switch
Two context maps are supported for the Logical Switch node:
  • Layer 2 Neighbors displays the Layer 2 neighbors associated with the selected logical switch.
  • Logical Switch to Host displays the topology of a logical switch, its connected VDS (virtual distributed switches), and the hosts under each VDS.
Two context maps are supported for the VM node:
  • VM to Layer 2 Neighbors displays the Layer 2 topology from a VM to DLR/NSX Edge or from a VM to its connected vSwitch and physical switches.
  • VM to Layer 3 Neighbors displays the Layer 3 topology between a VM and its gateway devices.
