Search for Automation Assets
You can search for automation assets, such as Qapp, Gapp, Runbook Template, Data View Template and Guidebook in the Search bar. All the matched Qapp, Gapp, Runbook Template, Data View Template and Guidebook will be centrally displayed in the search results pane.
Graphical user interface, text, application, chat or text messageDescription automatically generated
Information Note: The NetBrain System supports fuzzy search  for automation assets.
The following table list the properties supported to search for Automation Assets:
Table 1 - Properties for Searching Automation Assets
Automation Assets Search with name Search with description Search with tag Search with ID
Qapp
Gapp
Runbook Template (RBT)
Data View Template (DVT)
Guidebook
