Save the built-in CLI Template to another folder for modification.
NetBrain maintains the templates in the Built-in folder through Knowledge Cloud. However, NetBrain allows you to save built-in templates to other folders so that you can modify those templates to fit your use case.
  1. Right-click the template you want to edit or click to pull out the menu. Select Save as.
  2. Graphical user interface, text, application
  3. Select the folder you would like to save the template.
  4. Graphical user interface, application
  5. Follow Steps 2-3 in Create/Edit New Template to edit the template.
