Recalculate a Path
- Click the path on the taskbar to open the Path Browser.
- To select the path for recalculation, right-click the target path entry and select the corresponding menu from the drop-down menu.
Tip: To recalculate multiple paths at one time, select the paths by pressing the Ctrl or Shift key.
- Calculate Live Path — Calculate the path with live data.
- Calculate Path with Advanced Options — An Advanced Option pop-up window will show up, and you can select Path type and Data Source accordingly. See more details in Path Settings.
- Add to Path Calculation Bar — The Source and Destination IP will be populated to Path Calculation Bar.
Note: You can also click the following options in the right-click menu to resolve path-related issues:
- Resolve Path Gateway — It is mainly used when the gateways of some paths are not obtained, or the gateways are outdated. Clicking this option will resolve gateways in batches via selecting the first gateway to use from the currently available gateway list.
- Resolve Device Name — This option is used to convert the IP addresses of Source and Destination to Device Names in Domain, making it easier for users to browse and remember.
