Browse Network Objects and Context Map
The system can support various types of networks and provides built-in views for them. The Network pane is used to manage, organize and provide various views for network resources discovered from traditional networks and software-defined networks.
- Visualize Physical Networks
- Visualize Big Switch Networks
- Visualize Meraki Networks
- Visualize Software-Defined Networks
- Visualize Public Cloud Networks
Example: View the context maps of a firewall in a traditional network.
- Click Network in the taskbar.
- In the Network pane, select Physical Network from the drop-down list and then select Device Type.
- Expand the Firewall folder and select a specific firewall.
On the Context Maps tab, click Open Map to display the topology on a map.
Click the Device Details tab to view its property and interface details of the firewall.
