Managing Configuration Templates
To reuse configurations for network change tasks in the future, you can predefine it as a config template. When Defining the Change Node, you can directly load a config template instead of writing commands manually.
Proceed with the following steps to create a configuration template:
Click the start menu
, and select Incident & Change > Network Change.
In the Network Change pane, click Configuration Templates.
- In the Manage Configuration Templates pane, point to a folder and click the drop-down menu to select New Template.
Click Save to complete the configuration template.
