Manage the Integrated IT System
  1. Login to the System Management page.
  2. Click  and select Integrated IT System.
  3. To manage the integrated IT system, select the entry and click , you can:
  • Edit the integrated IT system
  • Delete the integrated IT system
  • Export the integrated IT system: The entry will be exported in a local file named <Integrated IT system name>.xits.
    Information Information Tip: To export all entries, click. The system will create a local zip file.
  1. To import Integrated IT systems from a file, click Import > Add Integrated IT System … > select a local file.
