Log in to Tenant Management Page
You can complete the following steps to log in to the Tenant Management Page.
- In your web browser, navigate to http(s)://<IP address of NetBrain Web Server>/.
- On the login page, enter your username or email address and password. The initial username/password is admin/admin.
Note: If you use SSO (Single Sign On), click the hyperlink of the SSO server to redirect to the login page of your Identity Provider. After your credentials are verified, you will be directly logged in to the system, and you can skip step 3.
- Click Log In.
- If you don't have the privileges of the system administrator, the page will be the Tenant Management page.
- If you have the privileges of the system administrator, the page will be the System Management page. Then go to step 4.
- On the System Management page, click
at the upper-left corner and select Tenant Management.
Note: It is not recommended to use the same web browser to log in to the system with multiple user accounts. Only the last logged-in user will be recognized as the current user.
