Integration with CMDB
NetBrain discovers network and keeps benchmarking network configuration through SNMP, CLI, and API.
To integration NetBrain and a third party CMDB system, there are 2 typical use cases:
  1. Network Inventory Synchronization
Network inventory synchronization may help to maintain identical inventory lists between NetBrain and a third party CMDB in your IT ecosystem.
  • NetBrain as the Single Source of Truth
NetBrain provides REST APIs for a third party system to query its device list.
  • Third Party CMDB as the Single Source of Truth
According to NetBrain auto-discovery mechanism and specific data model, NetBrain doesn’t allow a third party system to directly add a network device into the system. Instead, the third party system can add the IP of a network device into NetBrain discovery task and let NetBrain to discover it.
  1. Network Configuration Synchronization
Network configuration synchronization may help to maintain identical network configuration for the following items.
  • Device properties
  • Device configuration / data tables / any benchmarked device CLI outputs
  • Interface properties
  • Module properties
  • Network topology links
