Export Map to Word Document
You can export a map to the Word document and save it in a folder in the NetBrain System. When you export a map to Word, you can customize the data of the map to be included in the Word file. The exported word file of the map can contain both image and text information. Compared with other types of exported map files, an exported map file in Word format gives you more control over what data is included, such as the different views of the map and the device asset data of the map. Data of the exported map file is well organized and presented in a suitable format as needed.
The Word document exported from a map contains a topology map, device configuration, data table, and more.
