Enable GCP APIs
NetBrain System requires access to the following GCP APIs:
- Compute Engine API
- Cloud Logging API
- Cloud Resource Manager API
- Cloud DNS API
- Service Usage Viewer
- Stackdriver Monitoring API
Follow these steps to enable the required API libraries:
- In the GCP Console, go to the API Library page.
- Search or browse the library to find the required APIs like Compute Engine API.
- Select Compute Engine API to open it. Click ENABLE.
- Repeat steps 2 and 3 to enable all other required APIs.
