Network Settings
On the Network Settings tab, adjust the network settings for the scheduled discovery, including Front Server, private key, jumpbox, Telnet/SSH login credentials, privilege login and SNMP string.
Recommended Settings:
- Make sure only the relevant Front Servers and credentials are enabled to improve the efficiency.
- Make sure all relevant Front Servers are connected successfully.
- Make sure all relevant credentials are configured correctly.
- Adjust the order of Front Server and credentials to make sure the most commonly used ones are on the top of the list for better efficiency.
