Discover Azure Resources
Follow these steps to discover Azure networking resources via APIs:
- Log in to your NetBrain System.
- Click the Discover link from the Domain Management page.
- Click + Select API Servers and select the Azure API Server you just created.
- Click Start Discovery to start the Azure discovery. Run the discovery task manually or schedule a discovery task to discover Azure resources.
- Wait till the discovery finishes. The number of discovered objects will be displayed.
