Defining an External Approval Request
  1. Select the Planning node in the runbook.
  2. In the Approval pane, select External in the Approval System field.
    Information NoteIf the External option is disabled, see Approval Settings for how to adjust the approval option.
  3. Click Copy to copy and paste the runbook ID. The ID will be used to link with a ticket in an external system, thus building a connection with the Approval node in the external system for status synchronization.
  4. Create a change ticket in the external system and customize two fields in the ticket to save the Change Management ID and returned NetBrain URL.
  5. Create a business rule to define ticket and network change task status mapping and API calls in the external system. The rule mainly covers the following components:
  • How to access your domain.
  • Map ticket state and Change Management status.
  • Bind ticket ID to Change Management ID.
  • Call NetBrain API to Set Change Management Status when the ticket state changes.
Example: Define Status Mapping and API Calls in ServiceNow.
Code
* ServiceNow Script Example, Please follow this script
(function executeRule(current, previous /*null when async*/) {
var NB_API_PREFIX = 'http://your web API server address/ServicesAPI/API/V1/';
// login to get token & logout
var tokenEndPoint = NB_API_PREFIX + 'Session';
var tenantDomainEndPoint = NB_API_PREFIX + 'Session/CurrentDomain';
// credential to log into netbrain
var credential = {
username: 'admin',
password: 'admin'
var tenantDomain = { tenantId: 'xxx', domainId: 'xxx' };
// api time out default is 10 seconds
var API_TIME_OUT = 10 * 1000;
// store the netbrain api token
var nbToken = '';
var vendor = 'ServiceNow';
var stateMapping = {
'not requested': 0, // planning
'requested': 1, // pending
'approved': 2,
'rejected': 3
* Request the token
* @return hasToken: bool
function login() {
var request = newRequest(tokenEndPoint, 'POST', credential);
try {
gs.info('send request to netbrain, get the token'); //
var response = request.execute();
var responseBody = response.getBody();
var obj = new JSON.parse(responseBody);
nbToken = obj.token;
return nbToken.length > 0;
} catch (ex) {
// todo handle get token failed exception where to check this error msg
gs.error('get netbrain token failed.');
gs.error(ex.getMessage());
return false;
return false;
* logout netbrain, remove token
* @return
* @constructor
function logout() {
var body = {
token: nbToken
var request = newRequest(tokenEndPoint, 'DELETE', body);
try {
gs.info('logout netbrain.');
request.execute();
gs.info('logout netbrain success.');
} catch (ex) {
gs.error(ex.getMessage()); // should retry?
function addActivity(message) {
current.work_notes = message;
current.update();
* Request to set tenant & domain
* @return success: bool
function setTenantDomain() {
var request = newRequest(tenantDomainEndPoint, 'PUT', tenantDomain);
try {
gs.info('set tenant & domain info.');
return true;
} catch (ex) {
gs.error('set tenant & domain failed.');
return false;
return false;
* make an http call to netbrain to bind change request id to a cm runbook id
* @return
function apiCMBinding() {
var ticketId = current.getValue('sys_id');
var runbookId = current.getValue('netbrain_cm_id');// this might be different for different customer
var ticketName = current.getValue('number'); // this might be different for different customer
var endPoint = NB_API_PREFIX + 'CM/Binding';
var snState = current.getValue('approval');
if (stateMapping[snState] == null) {
gs.error('cannot find the correspond state from netbrain.');
return;
var postData = {
runbookId: runbookId,
ticketId: ticketId,
vendor: vendor,
ticketName: ticketName,
state: stateMapping[snState]
var request = newRequest(endPoint, 'POST', postData);
try {
gs.info('send change management binding request.');
if (obj.statusCode == 0) {
gs.info('change management binding to ' + runbookId + ' success.');
addActivity('change management binding to ' + runbookId + ' success.');
} else {
gs.info(obj.statusDescription);
// please change it to a proper msg, and this message is going to display on service now page
gs.addErrorMessage('binding Failed: ' + obj.statusDescription);
addActivity('binding Failed: ' + obj.statusDescription);
} catch (ex) {
gs.error('change management binding failed.');
gs.addErrorMessage('binding Failed: ' + ex.getMessage());
addActivity('binding Failed: ' + ex.getMessage());
* make a http call to netbrain to set cm runbook approval state
function apiUpdateCMApprovalState() {
var ticketId = current.getValue('sys_id'); // this might be different for different customer
var endPoint = NB_API_PREFIX + 'CM/approval/state';
return;
var postData = {
ticketId: ticketId,
vendor: vendor,
try {
gs.info('set change management state.');
var msg = 'set change management(' + runbookId + ') to state ' + snState + ' success.'
gs.info(msg);
addActivity(msg);
} else {
gs.addErrorMessage('update approval failed: ' + obj.statusDescription);
addActivity('update approval failed: ' + obj.statusDescription);
} catch (ex) {
gs.error('set change management state failed.');
gs.addErrorMessage('Error: ' + ex.getMessage());
addActivity('Error: ' + ex.getMessage());
function newRequest(url, method, data) {
var request = new sn_ws.RESTMessageV2();
request.setEndpoint(url);
request.setHttpMethod(method);
request.setRequestBody(JSON.stringify(data));
request.setRequestHeader('Accept', 'application/json');
request.setRequestHeader('Content-Type', 'application/json');
request.setRequestHeader('token', nbToken);
request.setHttpTimeout(API_TIME_OUT);
return request;
* update a value of service now
function updateColumnValue(table, primaryKey, primaryVal, targetColumn, targetVal) {
var gr = new GlideRecord(table);
gr.addQuery(primaryKey, primaryVal);
gr.query();
if (gr.next()) {
gr.setValue(targetColumn, targetVal);
gr.update();
* make a http call to netbrain to binding change request id to a cm runbook id
function main() {
var hasToken = login();
if (hasToken) {
gs.debug('login success.');
if (setTenantDomain()) {
// business logic
apiCMBinding();
apiUpdateCMApprovalState();
logout();
} else {
gs.info('login failed, quit now...');
main(); // run
})(current, previous);
