Continuous Network Assessment via ADT
The Automation Data Table (ADT) is a key component of the continuous network assessment across your whole network. ADT includes the critical assets (such as critical Application and Path, WAN Link, Device Failover, and Subnet) and associated intents and results, which can be scheduled to run in the network assessment. Further, ADT can store the dataset, which can be used to replicate, decode, and execute the intents.
ADT base table, which includes the assets, can be built from the device group, sites, application table, intent template, imported files, etc. The Column group, which is associated with the intent and results, can be created primarily from the intent template.
In the continuous assessment workflow, the data is collected through the benchmark and saved in the ADT dataset. The ADT dataset is used to decode, replicate and run intents.
The results of the continuous assessment are presented in the Summary Dashboard. The dashboard displays the key metrics, the top devices with the most alerts, and the detail charts, with each row as an assessment point and each column as the alert counts for a device group or site.
