Configuring Telnet/SSH Login
1) Select the Telnet/SSH Login tab.
2) Click Add to open the Telnet/SSH Login dialog box.
3) Select the authentication method, enter or select the non-privilege login credentials, and click OK.
Repeat steps 2) and 3) to add more entries if required.
Tip: The system polls these credentials in order when discovering network devices. To sort the order, right-click the target entry and select Move To Top or Move To Bottom. |
