Comparison Results
The identified changes in comparison results are categorized as follows:
CategoryDescription
AddedThe data only exists in the second data source or period.
ModifiedThe data exists in both the first and the second data source or period but has changed.
RemovedThe data only exists in the first data source or period.
EqualThe data exists in both the first and the second data source or period, and no changes occur.
Information Note: The comparison results for the same device and data type may be different if you swap Dataset 2 and Dataset 1 during the comparison because the Comparison feature takes Dataset 2 as a reference and uses Dataset 1 to compare with it. For example, a comparison result shows that a route entry has been added, but it will show removed when you swap the two data sets.
