Built-in Module Properties
The following table lists the module properties (case-sensitive).
Property Name | Display Name in Device Details Pane | Description |
name | Slot# | The modules of a device. |
type | Module Type | The port counts of a module. |
ports | Ports | The module type of a module. |
sn | Module Serial Number | The serial number of a module. |
hwrev | HW Rev | The hardware revision of a module. |
fwrev | FW Rev | The firmware revision of a module. |
swrev | SW Rev | The software revision of a module. |
descr | Description | The description of a module. |
