Built-in Interface Properties
The following table lists the interface properties/attributes (case-sensitive).
Property Name
Display Name in Device Details Pane
Description
name
Interface Name
The name of an interface.
ips
IPv4 Address
The IPv4 address of an interface.
ipv6s
IPv6 Address
The IPv6 address of an interface.
ipv6LinkLocalAddress
IPv6 Link Local Address
The IPv6 local address of an interface.
mibIndex
MIB Index
The MIB index of an interface.
bandwidth
Bandwidth
The bandwidth of an interface.
speed
Speed
The speed of an interface.
duplex
Duplex
The duplex of an interface.
intfStatus
Live Status
The state of an interface.
macAddr
MAC Address
The MAC address of an interface.
moduleSlot
Slot#
The module slot number of an interface.
moduleType
Module Type
The module type of an interface.
descr
Description
The description of an interface.
routingProtocol
Routing Protocol
The routing protocol configured on an interface.
multicastMode
Multicasting Mode
The multicasting mode of an interface.
mplsVrf
MPLS VRF
The name of the VRF configured on an interface.
mplsVpn
MPLS VPN
The MPLS VPN configured on an interface.
inAclName
Inbound ACL
The inbound ACL of an interface.
outAclName
Outbound ACL
The outbound ACL of an interface.
mode
Switchport Mode
The switch port mode of an interface.
vlan
VLAN
The VLAN number that an interface belongs to.
trunkNativeVlan
Native VLAN
The native VLAN of an interface as switch port.
trunkEncapsulation
Trunk Encapsulation
The trunk encapsulation protocol of an interface as a trunk port.
ipUnnumberedIp
Trunk Unnumbered IP
The unnumbered IP address of an interface as an unnumbered interface.
