Update vCenter Data in NetBrain through Benchmark Automatically
Since the discovery only retrieves basic data of your vCenter network, you need to execute a benchmark task to retrieve all data and build all components after the discovery, including topology, visual spaces and data views.
- Click the Start Menu (
) in the upper-left corner of your NetBrain desktop and select Schedule Task from the drop-down menu. - On the Schedule Discovery/Benchmark tab, click Add Benchmark Task.
- On the Frequency tab, define the task frequency.
- On the Device Scope tab, check the Select external API servers to retrieve data of SDN nodes check box, and select a vCenter server.
- On the Retrieve Live Data tab, select the VMware vCenter checkbox.
- On the Additional Operation After Benchmark tab, select all the checkboxes in the Build Topology and Rebuild Visual Space areas.
- Click Submit.
