Apply Data View Template to Visualize More vCenter Data
To visualize more vCenter data on a map, including topology, IP address, and configurations, you can apply a data view template.
Prerequisites: Proper configuration of Benchmark is required to use built-in data views. |
- On a context map, select Data View to expand the Data View pane.
- In the Data View pane, select Built-in Data View Templates > VMware > vCenter > Operation View [vCenter] and click Apply.
