Apply Data View Template to Visualize More Physical Network Data
To visualize more physical network data on a map, including topology, IP address, and configurations, you can apply a data view template.
Prerequisites: Proper configuration of Benchmark is required to use built-in data views.
  1. On a context map, select Data View to expand the Data View pane.
  2. In the Data View pane, select Built-in Data View Templates > Sample DVT > Infrastructure View and click Apply.
