Go back
A Single-Pane-of-Glass for Network Visualization? It’s Real!
October 26, 2021
Anyone who has spent time working with enterprise networks knows all too well the phrase “Single Pane of Glass”; it’s an entrenched way of describing what is supposed to be end-to-end visibility of an IT environment yet it has rarely been seen in practice. What I’ve observed is that instead of a truely integrated “single pane”, users often cobble together multiple tools and create their own discrete management workstation which has access to a litany of stand-alone tools. A far cry from the initial promise of a ‘single-pane’, this compilation of tools does nothing to solve the network management operational challenge:
  • Discrete tools do not allow operators to actually see the entire network end-to-end, from edge to cloud
  • The struggle of tedious integrations to achieve anything resembling coordintaed visibility
  • The hurt of only seeing network devices and not having access to the data associated with them
  • The sting of not being able to easily share a unified network view with your extended operational team
Creating a “single Pane of Glass” for end-to-end visibility has often been an empty promise, one that creates a lot of pain when examining the relationship between two opposite ends of the network. Different segments of the network are coming out of isolation. For example, NetOps needs equal visibility to the LAN as it does to what is going on in the datacenter. A problem in any part of the network can degrade end-user experience and IT service delivery performance; a siloed point-of-view on what’s happening in the network will not help resolve hybrid problems faster.
Additionally, “end-to-end” solutions often only refer to the “ends” within a vendor’s narrow ecosystem. It may be end-to-end as long as each end (and everything in between) is from Vendor X, then yes it’s end-to-end, but add in one switch from Vendor Y, and then all of a sudden, there is a gap in visibility. Or alternatively, a solution may be considered end-to-end as long as you don’t need visibility into the data center edge, the wide area or the Public Cloud. This simply doesn’t cut it for today’s digital infrastructures, where the most common applications span multiple data centers, co-location sites and public clouds.
I also see another gap when it comes to modern network visibility – it often only provides first-level visibility into the hardware and not into the myriad of data tools surrounding IT and networking teams. These tools (think ITSM and NPM, among others) provide the contextual information needed to take the right actions with network visibility. Not having access to their data and insights on the same pane as your infrastructure means you don’t have true single-pane-of-glass visibility. Data about what’s inside the infrastructure is not enough; you need to see what’s happening around it. Having to swivel-chair and piece together necessary data points to solve a problem is a struggle best avoided. Integrating these supporting applications should be API-driven, simple, and seamless. And what able the history view? Being able to compare today’s network pathways to last week’s same topology can usually identify issues that have arisen through poorly executed change management policies or other errant operational processes.
Finally, do you really have unified visibility if you’re the only one in your organization who can see it? Today’s networks are too complex and mission-critical to be the responsibility of just one person or just one team. Effective “Single Pane” visibility should be available to everyone touching IT service delivery, including network operations- an extended group that often includes DevOps, CloudOps and SecOps, among others. Subject Matter Experts should be able to collaborate in a single view, in real-time, from across the room or across the world. It is imperative to remove the delays associated with hand-offs and the tedium of “playing telephone tag” when business productivity is impacted.
Visualize Your Entire Network with NetBrain
All of the above sounds simple enough, right? The truth of the matter is that while “Single-Pane-of-Glass” visibility has been promised by many suppliers for quite some time, it has been less common for users to feel like they really have this unified visibility. Disconnects between different parts of the network and the ecosystem of tools surrounding them have almost become expected. Thus, many are rightfully skeptical of the promise of unified visibility. But for customers of NetBrain, they have had this for years and use it everyday!
NetBrain provides unified, single-pane-of-glass visibility across the entirety of your hybrid network infrastructure. By automatically discovering every node and device and leveraging ecosystem data to build a complete Digital Twin, NetBrain’s pane eliminates NetOps pain. Want to see it now, give us a minute to change your world.
Related Content
Company News
The Great Attrition
The Great Attrition has started and is affecting the Information Technologies industry in a profound way. For decades long-time IT professionals with deep experience and specific problem-solving skills were part...
Read More
Company News
A Letter from NetBrain's Founder and CEO
UPDATE June 1: NetBrain has released its own Professional Services scripts to enable users to deploy the Remote Work Toolkit and more to your instance of NetBrain Integrated Edition 8.X....
Read More
Company News
Missed Cisco Live U.S. this year? NetBrain has you covered
Last week, thousands of people attended Cisco Live U.S. in sunny San Diego for a week full of networking, live demos, exciting presentations and the latest technological innovations. Don’t worry...
Read More
